4 weeks ago
- last edited
4 weeks ago
I want to display the background hat as a wipeout in Archicad 29. Is this possible? In the PDF, one object doesn't show up underneath another, but it does in AutoCAD.
Solved! Go to Solution.
4 weeks ago
If you the background fill with the pen -1 it will produce a wipout.
4 weeks ago
Hi
It's just a DWG translator configuration.
You could try outputting it as is.
4 weeks ago
3 weeks ago
What about slabs with holes? In this case wipeouts are not produced, and doesn't produce any other fill either. It looks like wipeouts do not recognise "islands" in the way hatches do.
Do you have any suggestion so that export to dwg looks more like the drawing from AC?
2 weeks ago
What kind of holes? Manualy made poligonal holes?
Have you tried the Opening Tool? I'm refering to the one added in AC23, not the window or the door.
2 weeks ago
I tried both ways: opening tool or manual cutout, and it doesn't work either way.
2 weeks ago
- last edited
a week ago
You are correct.
When the slab does not have the hole, the wipeout works.
When I did the opening tool, the slab wipeout failed.
