‎2008-12-03 06:05 AM
‎2008-12-03 09:08 AM
sbrincat wrote:Seems the translator settings have been changed between exports. Both alternatives are possible to achieve.
Using one Translator (v.11) to save.dwgfrom two seperate files I am getting two different results. The translator is stored on the server so is the same .xmlfile in both instances. Both ArchiCAD files are v.11 Teamworked files.
One.dwgbehaves as expected - Cropped drawing in paper space and then cropped content in model space - all editable.
The other.dwg- Cropped drawing in paper space (all content is OK) and then nothing in model space! All layers are on and unfrozen and zoom extents, select all, achieves nothing.
What am i missing?
‎2008-12-03 11:17 PM
‎2008-12-04 01:02 PM
‎2014-09-10 10:32 AM
‎2014-09-10 10:42 AM
Wilt wrote:Do both machines (or the machine you are viewing the converted files on) have the ISO font installed?
We have the same problem. On one PC the translator properly translates the Arial font types to ISO, on the other PC everything continues to be in Arial in the exported result.
‎2014-09-10 01:55 PM
another Moderator
