We value your input!
export whole project file as DWG?
heathldesign
hey all, i must be missing something here, but i can't find out how to save the whole file as a DWG. views and layouts no problem, but i need to share the project with another trade and he want's to be able to interact with it and i just can't find any info on this. obviously i'm not wording my searches correctly.
Heath
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.1. AC 27, 6000 USA
4 REPLIES 4
Hello heathldesign,
I am not sure I understood your request. If your aim is to export a 3D DWG you are able to do this since a 3D view by "vectorial engine" instead of openGL.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
heathldesign
No, I’m working with a trade that uses AuotCAD and hasn’t been able to work with a pln file.
You should try Christophe's suggestion. I assume when you say the other trade wants to interact with the DWG file, it means that they need a 3D DWG which they can edit.
You can save a 3D DWG file from the 3D Viewpoint, just as Christophe suggested.
heathldesign
Ok, thanks guys.
