masterformat classification
alemanda
Is there any chance to have a preset masterformat classification?
Is it possible to create custom rules for classification?
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
26 REPLIES 26
alemanda
does anyone know the syntax how to give a ifcproperty set a value?
In other words I need to know how to assign a string value, for example "demo" to my property set ALMA - Spec.
In this way it would be possible to assign specifications, choosing by a preset list ... It would be great.
AC27 latest hotfix
Win 10 Pro 64bit
alemanda wrote:
Finished.
48 divisions implemented.
At the moment the classifications does not distinguish the type so every numbers can be associated to every item in the model.
Can I share it? Moderators, please advice about it.
This is a question I cannot answer right now. I will have to ask someone at GRAPHISOFT.
I went to the masterformat.com web page and checked the following document (which actually lists all numbers and titles included in Masterformat):
http://www.csinet.org/Home-Page-Category/Formats/MasterFormat/About-MF/MasterFormat-2014-Numbers-Tit...
On Page 1 it says:
For information about licensing use of MasterFormat for commercial or educational purposes, contact CSI at http://www.csinet.org/, csi@csinet.org or by calling 800-689-2900.
ARCHICAD has multiple standard Rule sets included such as Omniclass, Uniclass, etc. I don't know if GRAPHISOFT has to pay for the right to use these in ARCHICAD or not.
And I also don't know if such sharing the XML file (done by a user, not done by GRAPHISOFT) so anyone could use Masterformat in ARCHICAD constitutes commercial purposes or not.
So this is delicate matter which I will have to ask from GRAPHISOFT. I hope they will be able to answer.
Until then, please do not post the XML file on the Forum.
alemanda
Sure. That's why I asked before.
AC27 latest hotfix
Win 10 Pro 64bit
I got work back from GRAPHISOFT.
Please do no post the XML.
GRAPHISOFT will investigate the possibility of including Masterformat in future versions of ARCHICAD.
alemanda
Ok. No problem.
AC27 latest hotfix
Win 10 Pro 64bit
I am happy to report that both Uniformat and Masterformat (2016 edition) are now incorporated into ARCHICAD 20.
alemanda
Very Good !
AC27 latest hotfix
Win 10 Pro 64bit
