problem with MEP Systems
Hello,
* I am an student form the netherlands so my english can by bad, sorry for that. *
I have a student license for Archicad 15 and yesterday I installed the add on MEP systems.
Yesterday it worked fine, and there was a diffrent menu, of MEP.
but it irritated me so I closed the menu.
now i do need MEP for my work.
but I can't find it in the toolbars
'it is not in ellement attributes'
I hope someone can help me if they understand my problem.
David Maudlin
Guillaume:
You should try changing your Work Environment.
1. Open the Work Environment and select and apply the MEP Profile Work Environment Profile
2. If the MEP Profile is not there then go to Command Layout Schemes > Menus and add MEP Routing (this is the palette you are missing) and the other MEP commands to your menus.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
