Work with external software and open exchange formats (IFC, BCF, DXF/DWG)
Articles
Streamlined Load Input and EditManual Adjustment of the Structural Analytical ModelDetailed Structural Change List in Model Compare As architectural designs continue to grow in complexity, the structural analytical model follows the same growth and ends up becoming more comp...
  • 7762 Views
  • 2 likes
  • 0 comments
Table of Content Zones can be used for much moreDerive imposed loadsWhich zones generate live loads?1. Check the architectural model2. Check Zone Classifications3. Check Load CategoriesAdjust Load Categories inside ArchicadAdjust Load Categories outside Archicad4. Map your z...
  • 10565 Views
  • 1 likes
  • 0 comments
Frequently exporting SAF files to FRILO can be time consuming Structural engineers who use FRILO are currently spending quite some time exporting SAF files by selecting a save location and setting the path for export each time, which interrupts the workflow — causing a decre...
  • 9291 Views
  • 0 likes
  • 0 comments
Adjusting SAF Translator settings Currently, structural engineers can create and adjust structural analytical models in Archicad and eventually export them to the structural analysis software via SAF translators. However, in earlier versions of Archicad, there were only two ...
  • 8732 Views
  • 0 likes
  • 0 comments
Graphisoft has focused on further streamlining multi-disciplinary design workflows. Archicad 26 enhances the collaboration between structural engineers and architects with important structural analytical workflow improvements. Structural elements with multiple segments Somet...
  • 11657 Views
  • 2 likes
  • 0 comments
Archicad can share the structural analytical model with any external finite element analysis software that supports open-source file formats optimised for this purpose, such as Structural Analysis Format (SAF) After the structural analysis is done and the structural model is...
  • 8030 Views
  • 0 likes
  • 0 comments
The integrated structural analytical model within Archicad helps architects and structural engineers achieve real collaborative teamwork. This capability is available as of Archicad 24. While architects design with the help of physical models (BIM), engineers use simplified ...
  • 7173 Views
  • 1 likes
  • 0 comments
The structural analytical model integrated within Archicad helps architects and structural engineers achieve real collaborative teamwork. This functionality is available as of Archicad 24. To quickly find all the tools and features, use the dedicated Structural Engineering W...
  • 6775 Views
  • 1 likes
  • 0 comments
The structural analytical model integrated within Archicad helps architects and structural engineers to achieve real collaborative teamwork. This capability is available as of Archicad 24. Please check out the requirements you need to fulfill in Archicad to generate a correc...
  • 5809 Views
  • 0 likes
  • 0 comments
Follow the steps below when collaborating with someone using Revit Structure. In the example ARCHICAD 15 and Revit Structure 2012 were used but the process remains the same for current versions. 1) Set Element Parameters Open the selection settings dialogue box for elements ...
  • 6950 Views
  • 0 likes
  • 0 comments
Labels
