window schedule change wxh to hxw
Does there anyone know how to change the window list from wxh to hxw?
eric
7 REPLIES 7
eric
I guess the Height parameter has to precede the Width parameter in the list of parametes in the Scheme Settings Dialog.
Could you please have more specified? Are you saying in the work environment?
If you are talking about the Window Schedule, then you have to go to the Scheme Settings Dialog. In the Fields panel, the scheduled parameters are listed in the Schedule Fields field. Here grab that little doble-pointing arrow in front of the name of the Height parameter and drag it upward until the Height parameter precedes the Width parameter.
thanks for the reply. Sorry I have not make it clear.
The questions I had is when I placed a window in the plan, and selected the "Basic window marker" it showed the WxH, But I want HxW.
I was interested in this problem and also it turned out the script was not very difficult to modify. So I modified it.
There is a new parameter with which you can set how you want to have it displayed: Width-Height or Height-Width.
See it attached. Have fun with it.
Djordje
Could you please post it in the Depository?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Done. It is under Depository/08 Doors-Windows/Windows
