2023-01-22 01:42 AM - edited 2023-01-22 07:44 AM
EDIT : This was just me being embarrassingly unobservant.
Something seems to be off with the cabinet corner objects in AC26 so that the shape representation does not correspond to the segment settings. In the example below - the setting is set to one segment = no shelf yet it is represented with a shelf = two segments.
Solved! Go to Solution.
2023-01-22 06:37 AM
Go to Kitchen Cabinet Settings > Segment Details... > Number of Inner Segments and set it to 1.
David
2023-01-22 07:38 AM - edited 2023-01-22 07:48 AM
Had some nagging recollection of such a setting. Too tired being blind - thanks for setting me straight!
Post should be moved to design forum.
