Colouring polygons of a mesh.
I wonder if it is possible to color different polygons of a mesh to view in openGL.
5 REPLIES 5
alemanda
one method is to convert the mesh into a morph and change manually the color of each face ...
Depending on the size of the mesh it could be a big job ..
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
Lingwisyer
Guru
Rather than manually colouring, if you're converting to a morph, you could apply a projected texture onto it with all your colours done externally.
Ling.
thank you but converting a mesh into a morph I don't thing is a good idea, bcz we populate the drawing with too many polygons
Lingwisyer
Guru
Would be nice if you could project textures onto a mesh...
Defenetly
