Design forum
Defining Extrusion Geometry in GDL code
jakubc7
I am trying to create an object which is an extrusion of a profile (too complex to define manually with user input code).
Is there a way to implement 2D geometry (from polyline or fill) and use within a 3D GLD code of PRISM_ (or something more suitable).
I tried making a wall and/or column with a complex profile and "dragging" it into 3D code but that spits out very complex code which is unmanageable. I was hoping I could drag the fill or poly code coordinates and use them to define my _PRISM geometry?
I attempted this (using code from 2D poly or fill) in the past but never had success. Does anyone know a good way of achieving this?
ArchiCAD 10 - 25 | Windows 10
ARCHIcreate | Perth, Western Australia
archicad solutions | content creation | training | software implementation
2 REPLIES 2
Lingwisyer
Legend
You can reference Complex Profiles in GDL and extrude those. There is a thread from when this was introduced and it contains a link to the example object.
Ling.
Win10 | R5 2600 | 16GB | GTX1660
You can use the x & y co-ordinates from a POLY2, but you may have to watch the masking value or status code when you use them with a 3D shape.
For example in 2D
poly2_       6,      7,
                   0,            0,      1,
                   1,            0,      1,
                   1,            1,      1,
                 0.5,            1,    900,
                   0,          180,   4001,
                   0,            0,      1
but in 3D
prism_       6,      1.0,
                   0,            0,      15,
                   1,            0,      15,
                   1,            1,      15-2,
                 0.5,            1,    900,
                   0,          180,   4015-2,
                   0,            0,      -1
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Didn't find the answer? Start a new discussion
