Element Transfer Settings
Too Long
For some reason the objects in favorites are not placing on the current storey and are placing on the storey on which they were created (I assume this to be the case, whatever it is they are not placing on the current storey).
Ive tested with ETS checked and unckecked and Ive not previously had this issue.
Any ides how to fix this?
AC26 AUS Full
JeffH
I believe you need to go into your Element Transfer settings (Located in the Favorites pallets), and under objects, uncheck the homestory settings
AC24 / AC26
Win10
Ahh sorry, this is what I meant by saying "checked and unchecked" above.
thanks all the same.
AC26 AUS Full
