Floor lines
Polar Bear
Hello All,
Beginner questions:
Attached are images.
Two floors have different composite spec but the top layer is the same.  On plan it leads to a line (yellow circle), misleading for site crew.
How can we avoid this line?  I have tried solid operation connect, it didn't work.
Thanking you
Kind Regards
pb
ā€ƒā€ƒā€ƒ
Screen Shot 2021-11-13 at 11.32.50.pngScreen Shot 2021-11-13 at 11.32.39.pngScreen Shot 2021-11-13 at 11.32.35.png
Archicad 25 - 5010
Macbook pro 13" /Big sur 11.4 + External 4K 27"
Eduardo Rolon
In "Model View Options" under "CONSTRUCTION ELEMENT OPTIONS" change the "Slab" option to "Eliminate".
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
1 REPLY 1
Eduardo Rolon
AC29 US/INT -> AC08
another Moderator
