2010-07-11 09:42 PM
2010-07-12 10:48 AM
2010-07-12 03:18 PM
2010-07-13 04:41 AM
2010-07-13 07:02 AM
2010-07-13 10:04 AM
2010-07-13 02:24 PM
alexliz wrote:Alex:
For example, the bathtub in ArchiCAD 13 only has one hotspot, along its long side, in the middle; also another one at the drain point.
alexliz wrote:This will work only if you Save the library part to extract it from the .lcf file, but the you will need to add it to your libraries (better to Save As... so the part has a different GUID so it is not confused with the original part).
Actually, I had already selected one of the objects (the Double Bed 13.gsm) and then gone into File->Libraries and Objects->Open Object...
Then in the main object window (which was the [Read Only], as the library was the .lcf) I clicked on Details... at the top, and in the next window I checked the box 'Hotspots on bounding box'.
Then I went to save the object, but with it being a [Read-only] file I couldn't, so I discarded the changes. BUT...
2010-07-13 02:29 PM
2010-07-13 02:51 PM
2010-07-13 02:52 PM
Subject | Likes |
6 | |
4 | |
3 | |
3 | |
3 |
