Material intersection priority
Polar Bear
Probably an easy question:
Why is it that the material priority isn't working between roof and wall: in both method : without seo and with seo upward extrusion?
Thanks a lot!
Screen Shot 2022-06-25 at 18.20.47.pngScreen Shot 2022-06-25 at 18.20.36.png
Archicad 25 - 5010
Macbook pro 13" /Big sur 11.4 + External 4K 27"
Miha Nahtigal
Use Connect->Merge function.
BIMquants.comBETA - Quantities and Costs Estimation with Archicad AddOn :: rushing to publish a beta preview
Miha Nahtigal
Some elements have automatic connections (automatic priority based junctions) and others don't.
It is all explained in the reference manual - search for Model Element Connections.
Thanks! it worked, my ignorance!!!
Archicad 25 - 5010
