2019-10-15 11:46 PM
2019-10-16 03:04 AM
4hotshoes wrote:
Project Map to View Map"
As I place he Interior elevation symbol on the floor plan all of the Elevations generated assume the plan view settings in the Project Map. I select all the newly generated elevations and manually change the View Settings, but they are not sticking if I click away. Then do it again and I move them over to the View Map right away and they are saved. However,I thought I could somehow save all of View Settings so I do not need to keep doing it manually. If so, how?
4hotshoes wrote:
View Map to Layout Book:
I also don’t want the Drawing label for each interior elevation to show the Graphic scale on the drawing label when the drawings are dropped into a layout sheet. I keep manually changing that too. How do I change the default.
Subject | Likes |
5 | |
4 | |
3 | |
3 | |
3 |
