Object reference point for zone
pejotu
We have some objects, that need to be located bridging in-between two zones.
When we try to schedule these objects, they can't display any zone information. Only moving the geometric ("bounding box") center point of the object inside one of the zones lists it there.
Is there any way to specify the point which is used to locate the object in a certain zone? (obviously a workaround would be to stretch the object with invisible points so as to move the center point, but from a user point-of-view this is not an optimal solution)
0 REPLIES 0
Learn and get certified!
