Section Story Levels not showing on layout, Why?
4hotshoes
They show on the section, but not on the placed section on a layout. Sample below. Where is the setting to change this?
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
In the 'Storey Level' settings of your section settings you will find there is an option to 'Show Storey Levels' > 'Display Only' or "Display & Output'.
You need the latter.
1 REPLY 1
