2003-11-17 05:34 AM
2003-11-17 07:17 AM
2003-11-17 07:22 AM
2003-11-17 07:51 AM
tprokop wrote:As David said, it is fixed. Furthermore, the GDL objects can be translated straight into blocks, with the visible (and in cas of zones hodden too) attributes present and editable.
We are an A/E firm that runs Archicad for architecture and Autocad for our engineering. I am familiar in running translations but am having a problem with some of my objects.
When saving out to Autocad, objects with text assigned in the GDL code come in correctly, but any variable text entered in the parameters window is coming into the autocad drawing in a different location. Is there a way to fix this with my code or a translation suggestion?
2003-11-17 09:18 AM
2003-11-17 10:17 AM
tprokop wrote:No, depending upon how you have your translator set-up. As long as you do NOT set the translator to "Explode complex ArchiCAD Elements" the GDL Objects will automatically translate into AutoCAD Blocks.
I like the idea of the Autocad block but am unsure of how to do this. Do I need to create a block with the same name and use it in a template to carry this information across in translation?
2003-11-17 10:25 AM
tprokop wrote:You have to have the layers and the DWG template defined in order for the BYLAYER option to work.
I have used the objects in 6.5 (our current version in use) and the text came in to the correct location but did not update the properties to by-layer.
