Greetings all, using the Masterzone (formerly known as Superzone-2), the Measured Area calculated value is incorrect. In the attached screenshot you can see the Measured Net Area is 221 SF, however the Measured Area returns an incorrect value of 6,000 SF. Any ideas will be greatly appreciated.
Thanks, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
