tree shows plan view in elevation
I place a tree in elevation but shows as plan view, no where in selection setting to set "side view" as per the tutorial
Regards
You are placing a 3D tree in an elevation or section, this will only show the 2D plan view of the tree.
If you want to use a 3D tres place in plan or a 3D view, if ok with just a 2d tree use the 2d trees from the library
Regards
Scott
Regards
Scott
done, thanks Scott
