Browse
Graphisoft Community
All
This category
This board
Articles
Users
Products
Design
Design articles
Design forum
Document & Visualize
Document articles
Visualize articles
Document & Visualize forum
Collaborate
Teamwork articles
Data Exchange articles
Project Management articles
Collaborate forum
Setup & License
Let's get started!
Setup & License articles
Setup & License forum
Get Together
What's new?
Wishes forum
Developer forum
Graphisoft User Group
Graphisoft Insights
Challenges
Parametric Object Factory
My Graphi Story
One Override to Rule Them All
Snow Globe Challenge
Português (Brasil)
日本
International
search
Help
All
This category
This board
Articles
Users
Products
Design forum
Graphisoft Community (INT)
Design
Design forum
tree shows plan view in elevation
Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Pin this post for me
Bookmark
Subscribe to Topic
Mute
Printer Friendly Page
Go to solution
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report Inappropriate Content
2020-11-27
10:23 AM
Hello,
I place a tree in elevation but shows as plan view, no where in selection setting to set "side view" as per the tutorial
Regards
Solved!
Go to Solution.
Labels:
Labels:
GDL
Library
Preview file
267 KB
All forum topics
Previous Topic
Next Topic
1 ACCEPTED SOLUTION
2
Go to solution
Solution
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
2020-11-27
11:54 AM
You are placing a 3D tree in an elevation or section, this will only show the 2D plan view of the tree.
If you want to use a 3D tres place in plan or a 3D view, if ok with just a 2d tree use the 2d trees from the library
Regards
Scott
Go to solution
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
2020-11-27
12:51 PM
done, thanks Scott
Post Reply
Didn't find the answer? Start a new discussion
Create new topic
Related articles
Window appears offset from Complex Profile wall
in
Design forum
Copy Paste grayed out? How to transfer modeled elements from one project file to another?
in
Design forum
Elements not showing in section view
in
Design forum
Modelling my hand-drawn University Project in Archicad
in
Design articles
Archicad 26 is stuck generating section/elevation projection.
in
Design forum
Labels
2D Elements
2
Add-ons
23
Annotation
1
Attributes
4
Beams
22
BIMx
2
Classification & Properties
1
Columns
13
Complex Profiles
44
Composites
30
Curtain Walls
28
Design
17,321
Doors & Windows
111
Drawings
6
EcoDesigner
174
Edu
473
GDL
6,949
Goodies
3
Graphic Overrides
1
Graphisoft Insights
1
Grasshopper
218
Intersection
34
Layouts
2
Library
6,895
Mesh
24
Morphs
17
Objects
90
Openings
21
Other
191
PARAM-O
11
Performance
2
Presentation
1
Project Management
1
Project Presentation
2
Publishing
1
Rendering
1
Rhino & Grasshopper
25
Roofs
1
Roofs & Shells
37
Skylights
8
Slabs
27
Solid Element Operations
23
Stairs & Railings
49
Student
478
Surfaces
2
Sustainable architecture
174
Teamwork
1
Templates
3
Tips & Tricks
232
Troubleshooting
99
UI
1
Views
2
Walls
79
Latest solutions
Railing posts at the very ends of base line
Design forum
Release objects half-way with a shortcut command
Design forum
Trim function issue
Design forum
space between stories
Design forum
Hatch pattern shows through the doors and windows ...
Design forum
View all
Most liked posts
Subject
Likes
Pritzker and Archicad
5
Re: Dark Mode Bug
4
Re: Dark Mode Bug
3
Re: Dark Mode Bug
3
Re: lock to z axis 3d view
3
View all
Create new topic
