GDL
ARRAY PARAMETERS
Cosminn
Hello everyone, my name is Daniel. I started creating more GDL objects, and i have a problem with array parameters, maybe you can help me. If i have 3 parameters A, B and C. IF A=2; B=3 then I want that parameter C have 2 values because A=2 and another 3 values because B=3. So I want 5 values for parameter C. I hope you will understand, i'm sorry for my english. Thanks
Sincerely,
Daniel
7 REPLIES 7
Nader Belal
Mentor
Try to explain this in a better way
A good friend of mine have once told me that I“m so brute that I“m capable of creating a GDL script capable of creating GDLs.
That is a 7 year old post.
I would hope Cosminn is not still looking for a solution.
Nader Belal
Mentor
Either he marks it as solved or someone must delete it
Lingwisyer
Guru
There a quite a few posts around in which questions have been posted and no reply has come forward...
Cosminn
Hello everyone - Yes - Ive found the answer for this post!
Sincerely,
Daniel
Any chance you could possibly explain?
Otherwise this really is a pointless post.
Cosminn
Agree - I will share!
Sincerely,
Daniel
