Archicad C++ API
Call Archicad Wall command from own dialog
Lawoks
Hi Experts,
I was searching for similar topic, but did not find the answer.
Is it possible to run a typical command, e.g. draw wall from a custom dialog?
Example:
- list field
- insert key
1. I select a wall from the list of existing walls
2. I press the button insert wall = I invoke the Archicad command.
An example from the SDK: Element_Test -> Create Curve Wall does not simulate a wall during insertion, and the Archicad command even has a drawing method selection panel.
Sorry if the question is naive, this is my first steps with Archicad SDK
all the best
Slawek
1 REPLY 1
Lawoks
I found a suitable example in SDK.
It works properly for: window (return DWRC), door (return ROOD) , lamp (return HGIL)
For wall or column WriteReport return empty space (simply nothing)
Here is the link to the Example code from SDK:  APIEnv_​SetToolBoxModeID
and code - I sign the line which return "nothing"
Do you have any advice pls?
regards
Slawek
