Developer forum
Can Renovation status be used for different 2D scripting?
Mats_Knutsson
Thinking of trees and using renovation filters... new tree, existing, to be removed... I would like the 2D script to use renovation status....is is possible and/or doable?
/Mats
AC 24 SWE Full
HPZbook 32GB i7 7820HQ 2,9 GHz
Quadro M2200 2GB
9 REPLIES 9
DGSketcher
Seems like an important missed variable in GDL. The only apparent access is through Autotext values but I think this is restricted to certain applications such as TEXT2.
Apple iMac macOS Big Sur / AC24UKI (most recent builds)
GDL wrote:
Built-in Properties
These commands return the folder names, parameter names and parameter values of built-in properties on the "Classification and Properties"
tabpage (ID and Categories, Renovation, IFC Properties).
I never tried, but perhaps Build-in Properties can do the trick. (Page 519)
Mats_Knutsson
Braza wrote:
GDL wrote:
Built-in Properties
Hmm..would be interesting to see if it can be used. I'm not that much into GDL to understand how i would use it.
AC 24 SWE Full
Quadro M2200 2GB
Dominic Wyss
It works but you will get a localized string.
Would be nice if Graphisoft could offer a global integer parameter (-1; 0; 1)
From gdl.graphisoft.com:
DIM folderNamesArray[]
n = APPLICATION_QUERY ("OwnCustomParameters", "GetParameterFolderNames()", folderNamesArray)
for i = 1 to vardim1(folderNamesArray) step 3
    DIM parNamesArray[]
    querystring = "GetParameterNames(" + folderNamesArray + ")"
    n = APPLICATION_QUERY ("OwnCustomParameters", querystring, parNamesArray)
    text2 0, 0, querystring
    add2 1, -1
    _nLines = 1
    for j = 1 to vardim1(parNamesArray) step 3
        parValue = ""
        querystring = "GetParameter(" + parNamesArray + ")"
        n = APPLICATION_QUERY ("OwnCustomParameters", querystring, parValue)
        text2 0, 0, querystring + ": " + parValue
        add2 0, -1
        _nLines = _nLines + 1
    next j
    del _nLines
    add2 0, -_nLines
next i
so in short
renoStatus = ""
_r = APPLICATION_QUERY ("OwnCustomParameters", "GetParameter(Renovation.RenovationStatus)", renoStatus)
text2 0, 0, renoStatus
Cheers
AC23 CHE - macOS Catalina
Mats_Knutsson
    DIM parNamesArray[]
    add2 1, -1
    _nLines = 1
        parValue = ""
        add2 0, -1
    next j
    del _nLines
    add2 0, -_nLines
next i
so in short
renoStatus = ""
Cheers
Thx.
With my very tiny GDL skills I cad get the code to display reonvation status with the renoStatus parameter. How can I connect an IF THEN ELSE to use the status? IF renoStatus = "New" THEN....circle 0,0,1 ELSE IF...etc
AC 24 SWE Full
Quadro M2200 2GB
Dominic Wyss
Yes. exactly like that
renoStatus = ""
if renoStatus = "New" then !! <- String is localized. So in your case it should be "Ny"
    !do something
else
    !some code
endif
Important: the returned string is localized. So in your case it should be "Ny"
Thanks Dominic! Much appreciated.
And thank you Mats for posting your question.
And I agree... It would be better if the parameter was a global integer.
Though I think the whole Renovation Status should be incorporated to the Properties.
And finally, introducing the Model Filter View Option.
Mats_Knutsson
renoStatus = ""
    !do something
else
    !some code
endif
Many thanks Dominic!
I got it to work . Now I need to get the symbols from our landscapers and start coding.
Mats
AC 24 SWE Full
Quadro M2200 2GB
Mats_Knutsson
We strongly don't like the dubious interaction between Renovation filters, MVO and GO. Polish parliament kind of.
AC 24 SWE Full
Quadro M2200 2GB
