Developer forum
Disable Lable UI
I read it anywhere, but I can't find it anymore:
Is there a way to disable some of the standard UI panes of the label tool by GDL commands?
Joachim Suehlo . AC12-25 . MAC OSX 10.15 . WIN10
5 REPLIES 5
I think the only panel in the Label Settings Dialog you can affect by GDL commands is the "Symbol Label Custom Settings" panel. What you see there is defined in the User Interface Script of the Label.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Thank You Laszlo,
I found it now: it is in the compatibility options, see image.
It disables the Text Style Tab
Dominic Wyss
Hi Joachim
There are many other UI elements that can be controlled via optional fixed named parameters. Especially frame control and orientation options:
http://gdl.graphisoft.com/reference-guide/parameters-for-labels
Dominic
AC23 CHE - macOS Catalina
runxel
Ace
But how can I prevent the label of having a pointer?
You cant just LOCK "LABEL_HAS_POINTER" (or hide).... even with the option Jochen found above.
AC 24 [ger] | Win 10 | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Peter Baksa
Sorry runxel, that's not possible. You can give a 2d text feedback to the user to please turn it off or on.
Péter Baksa
Software Engineer, Library as a Platform
Graphisoft SE, Budapest
