GDL
Door with Profilemanager
Hmooslechner
Hi there!
I'd like to point your attention to my new gdl-development using the profile-manager-profiles for door-Library-parts.  My goal is, to get out the most from very few user-actions.
For me - the only 2 variables for a Door should be the egress-measures. The rest should automaticly follow.
Then - using profiles of course - i have to select some and as next - i thought - it would be beneficial to select Arc-Forms for the "above"-geometry. All this is now functional.
https://www.dropbox.com/s/fpwj8v9p908pwr2/Türrahmen%20mit%20Profilmanager13.bpn?dl=0
I also thought, it would be a good idea to "see" whats happening, when pulling on an editable hotspot and so, i implemented the visual construction-methodes when a hohtspot is drawn.  As construction-methodes for the curves, i used the arc-forms from the german wikipedia.  https://de.wikipedia.org/wiki/Bogen_(Architektur)
www.youtube.com/watch?v=ZsX9KlmPdG0
10 REPLIES 10
Um, what I the who nose what's it with a side of sugar.  So much respect and just holy wowness. This is the beginning of a new era of expected opening.
Hmooslechner
Some improvements - simple doorleaf..
https://www.youtube.com/watch?v=yiYDRtTqjGc
https://www.dropbox.com/s/uubcvmg86mwhtls/T%C3%BCrrahmen%20mit%20Profilmanager15.pln?dl=0
Lingwisyer
Guru
Wow... that math...
DGSketcher
Legend
I would have been impressed by a trapezoid door with profiles, that is awesome!!!
Yes, very impressive to automate all those different curves.
Red
Very nice! I need to dig a little more into GDL on how to call a "Complex Profile." This has been something I have wanted to do for a while now. I understand the basics of GDL but need to learn more.
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
Hmooslechner
some further progress:
https://www.dropbox.com/s/z1it2rgozzh2wy3/T%C3%BCrrahmen%20mit%20Profilmanager16.pln?dl=0
@Red Open up param-o place a profile, save the object and then open the code. That will shed some light on the coding process.
Hmooslechner
Added some additional functions:
AC25eduAut:
https://www.dropbox.com/s/lrzo6j3bzzj48ms/T%C3%BCrrahmen%20mit%20Profilmanager17.pln?dl=0
