Developer forum
GDL: fill selection
runxel
Ace
Is there any way to let the user have select only solid fills (those with %, also named translucent fills)?
I know there is FILLTYPES_MASK, but thats the type of the usage of the fill.
Of course I could just loop through all fills and hope the user has named the fills in a way I can filter them out. But that is too risky for an object that's not used inhouse alone.
Mostly AC 26 on Mac | Author of SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
9 REPLIES 9
Will this help? ...
n = REQUEST ("class_of_fill", index, class)
Returns class of the fill identified by index in the class variable. Causes warning if used in parameter script.
Versions 6.5 to 25
Podolsky
Ace
Maybe you can use request:
So, you need to scan all fills, detect only fills with class = 3 (translucent), record all into array and use array in VALUES{2} to limit fills selection.
runxel
Ace
Yeah nice idea, but since you can't use it in the param script this approach doesn't work.
Silly.
Podolsky
Ace
To be honest - this limitation when some requests are not working in Parameter script make a lot of nice things to do in GDL impossible.
In earlier versions this limitation did not exist. I'm wondering, why not to work on this issue and solve it one day? Post a wish?
runxel
Ace
True .... 😞
Anyway, I "solved" this issue by defining a translucent fill and the user can determine the transparency.
But man, still a silly way.
Podolsky
Ace
I know how to do it!
First set a variable for the fill as integer (small cubes icon). The name of variable is customFill
Then write this code in parameter script:
DIM fillsIndexArray[]
DIM fillsNameArray[]
FOR n=1 TO 1000
	fillsIndexArray=n
	fillsNameArray=STR(n, 1, 0)
NEXT n
VALUES{2} "customFill", fillsIndexArray, fillsNameArray
And then this code in User Interface script:
DIM pixIdxArray[]
m=1
FOR n=1 TO 1000
	rClass = REQUEST ("class_of_fill", n, class)
	IF rClass THEN
		IF class=3 THEN
			rName = REQUEST ("Name_of_fill", n, name)
			IF rName THEN
				fillsIndexArray=n
				fillsNameArray=name
				pixIdxArray=''
				m=m+1
			ENDIF
		ENDIF
	ENDIF
NEXT n
UI_INFIELD{4} "customFill", 5, 65, 200, 20,
				8, "",
				0,0,0,0,0,0,
				pixIdxArray, fillsNameArray, fillsIndexArray
Result is showing on preview image. You can also add additional code to re-organise fills list, that it would follow alphabetical order. If you need help with that - I can share the script about it too.
runxel
Ace
Nice GDL Kung Fu.
Love it, thanks Podolsky.
Lingwisyer
Legend
Hey Podolsky, how would you go about achieving this? Also, is there a way to check if a fill exists or not?
I saw this thread but do not get what is happening...
Ling.
Win10 | R5 2600 | 16GB | GTX1660
Podolsky
Ace
Ling.
Please look as Schedule Setting Tool from my library, at the end of Parameter script there is subroutine that organising arrays in alphabetical order.
https://archicad-talk.graphisoft.com/viewtopic.php?f=37&t=72947
