2021-05-17 05:34 PM - last edited on 2021-09-14 09:11 AM by Noemi Balogh
Solved! Go to Solution.
2021-05-18 12:07 PM
DIM fillsIndexArray[] DIM fillsNameArray[] FOR n=1 TO 1000 fillsIndexArrayAnd then this code in User Interface script:=n fillsNameArray =STR(n, 1, 0) NEXT n VALUES{2} "customFill", fillsIndexArray, fillsNameArray
DIM fillsIndexArray[] DIM fillsNameArray[] DIM pixIdxArray[] m=1 FOR n=1 TO 1000 rClass = REQUEST ("class_of_fill", n, class) IF rClass THEN IF class=3 THEN rName = REQUEST ("Name_of_fill", n, name) IF rName THEN fillsIndexArrayResult is showing on preview image. You can also add additional code to re-organise fills list, that it would follow alphabetical order. If you need help with that - I can share the script about it too.=n fillsNameArray =name pixIdxArray ='' m=m+1 ENDIF ENDIF ENDIF NEXT n UI_INFIELD{4} "customFill", 5, 65, 200, 20, 8, "", 0,0,0,0,0,0, pixIdxArray, fillsNameArray, fillsIndexArray
2021-05-17 05:49 PM
2021-05-17 05:55 PM
2021-05-17 07:18 PM
2021-05-17 10:46 PM
2021-05-18 11:02 AM
Podolsky wrote:True .... 😞
To be honest - this limitation when some requests are not working in Parameter script make a lot of nice things to do in GDL impossible.
2021-05-18 12:07 PM
2021-05-18 12:48 PM
2021-07-21 04:00 AM
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win10 | R5 2600 | 16GB | GTX1660 |
2021-07-21 06:04 AM
Lingwisyer wrote:Please look as Schedule Setting Tool from my library, at the end of Parameter script there is subroutine that organising arrays in alphabetical order.
Hey Podolsky, how would you go about achieving this? Also, is there a way to check if a fill exists or not?
I saw this thread but do not get what is happening...
Ling.
