2022-10-04 09:40 PM
I installed the latest version of revit Archicad ifc exchange plugin today. I am getting an error denoting server not found whilw importing an IFC from Archicad 26 into revit 2023. Kindly help.
2023-02-28 03:48 PM
I have the same problem. Have you found a solution? What operating system are you using?
2023-03-21 09:28 PM
Anyone have a solution for this?
2023-03-22 10:51 PM
Can you guys show a screenshot of this? If this happening in Revit when using the "IFC Model Exchange with Archicad for Revit 2023" Add-In?
2023-03-23 09:55 AM
Hi everyone. We have been made aware of this issue and we are trying really hard to pinpoint the problem at the moment. We have a hunch that this error occurs when the "IFC Model Exchange with Archicad for Revit 2023" Add-In is installed on a different device than Revit is running on. So maybe you try to access the addin from a server on a network location and this could cause some of these errors.
Could any of you guys confirm this is the case or maybe you see some particularity in your use-case that could cause this?
2023-04-03 06:59 PM - edited 2023-04-03 07:04 PM
That is not the case for me. Revit is installed on my hard drive for both my desktop and my laptop. The IFC plug-in is also installed on each hard drive. Neither my laptop nor my desktop will import the IFC.
