Manuel wrote:
I hope this post is in the right place;).
1. Can I define the subtype in param-O or only in the gdl-editor?
As far as I can see, all GDL Objects created by Param-O will have the "Model Object" Subtype, You will have to open the generated Object for editing and change the Subtype there.
2. Is there a command to implement some GDL-Scripts in param-O like Python in Grasshopper?
Thanks. 😉
You can use the "GDL Shape" Component in the "Extras" group. Place it, then double-click the "Transformation" Input. In the dialog that opens, you will see the "Script" field. This is where you can enter any GDL 3D script just like you would enter it in the 3D Script Window in the GDL Editor. You can refer to the A, B, C, D input with the $a, $b, $c, $d texts in the script.
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
