Archicad Numerator Addition
Kikoria
Hello, can anyone help me with the Numerator addition? I can't exactly remember where I found it. I downloaded it and installed. It was super helpful for working on floor plans or section/elevations. It was creating the order automatically by inputting the amount of numbers, distances etc.
Hope you guys use it too.
Kind regards,
Tamaz Kikoria
Architect
Technical Examination and Design Department
GEORGIAN WATER & POWER
Rubia Torres
Hi Kikoria,
Was it an add-on or an object in Archicad? If you have more details, please share.
For example, in what Archicad language and version did you have such a tool? And how did it work exactly?
I could only guess this thread might help you.
Best,
Rubia Torres
Community Specialist | GRAPHISOFT SE
Need help refining your Archicad skills?
Check our Modeling knowledge base for the best workflow + tips&tricks!
Rubia Torres
Hi Kikoria,
Best,
Rubia Torres
Oh, yes, that's it. It was an object. Many thanks!
Kind regards,
Tamaz Kikoria
Architect
