As far as I know they should be updating automatically when you open the layout then.
There is an option in the Work Environment, but that only relates to background updating (version 20+).
The layout should still update when you open it regardless of this WE setting.
The only other thing I can think of is that you are linking to a drawing from another file.
In my image you will see it says the source file is "Internal".
Does yours show the same?
