Custom Window labels
Hi Guys
I'm trying to create a note within window properties for labeling - eg lintels and fixings type '2/190x45 lintel fixing type: E' i want to link that information to a label on a floor plan and a schedule so that i only have to write the lintel size once and its linked to that window. Iv tried using 'user defined 1' etc which works with the schedule but there is no auto text linking to that property so i can't make a custom label. Can anyone point me in the right direction. I cannot fathom why there wouldn't be a property in the window settings for lintel size, no matter where you are in the world, windows need lintels
Hello Sam,
Did you try to find it into "Library item parameter" instead of "Add fields" ?
You are able to find others parameters like this...
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
Hi Sam,
Which Archicad version are you using? Can you also post a screenshot of how you would want the result to look like? (Draw it using lines and text.)
