Find the next step in your career as a Graphisoft Certified BIM Manager!
Project data & BIM
DOOR LEGEND - GRAPHICS
Gisele
Attached is a screenshot of the door legend.
How to make doors D2 and D3 show as line work (without solid hatch) in the door legend without changing the doors' assigned material?
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
You can set up a Graphic Override to override all of the fills associated with the door to be white or transparent and then save the Schedule as a View in the Project Map and apply that Graphic Override to the saved View.
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.1.1
macOS Sonoma (14.2)
Lee Hankins
macOS Sonoma (14.2)
Gisele
Thank you!
