Elevation is empty
Hi.
I have been working on a project. When I try to generate an elevation but Achicad won't show anything.
Any ideas on what the problem could be?
4 REPLIES 4
Eduardo Rolon
Presuming that you have modeled walls etc and you are placing lines in floor plan (which will not show up), things to check:
• Layers are on
• Elevation marker range includes the model (set to infinite)
• Zoom Extends to see the model
• Renovation Filters are the same
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
gdford
If the marker settings are set to "Linked Marker" instead of "Source Marker" there will be nothing in the section.
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
Not true.
It will show you what ever it is linked to.
gdford
correct - but before it is linked it is empty - not a live section.
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
