File search path
eldhead
Hi!
Is it possible to have file search path written down on pdf:s when publishing? I know I can get the host filename by autotext but the individual pdf?
Like Word...last saved at...
Archicad 7 - 24, HP ZBook 15 Mobile Workstation, Win 10
No, the file path to the saved PDF is not something that can be added to a published PDF. I'm not sure I understand your comparison to Word ... the last saved location isn't the location of an exported PDF, but of the docx file itself, isn't it?
The full path to the PLN that is being published can be obtained as you say - and also can be displayed on each PDF page in the footer if you select the Header/Footer Settings.
One of the forum moderators
eldhead
Ok, that would have been very handy because we have files with the same name all over the server.
Word...you are right, It´s not the pdf searchpath it´s to the docx file just like the pln.
