Document & Visualize forum
How do I do this Dimensions Marker format?
INTEXHOMES
Dimension marker 22 was a great marker. Unfortunately removed from the current Archicad version. Does anyone know how I achieve this format?
Gerald Hoffman
You could set the Property ID of the Door to 2668 and use the Property Label. It is quite versatile. You can use a frame if you want and have it opaque.
Gerald
"The simplification of anything is always sensational" GKC
AC 25-4013 USA, CadImage Tools
2019 MacBook Pro 16" w/ AMD Radeon Pro 5600M GPU
OS X 11.6
2.4 Ghz 8 core i9, 64 GB RAM
27" LG 5K Monitor
Gerry Leonor
you could use an associative label tool that calls up whatever parameter it is you're grabbing from the door.
above is an example calling up the panel height.
AC25 | Win10 | 64 bit | 16Gb RAM |Intel i7 8700 @ 3.20Ghz
come join our unofficial Discord server
https://discord.gg/XGHjyvutt8
It's not displaying the format that I am after.
Gerald Hoffman
Gerald
OS X 11.6
27" LG 5K Monitor
