2022-09-07 04:59 PM
Dimension marker 22 was a great marker. Unfortunately removed from the current Archicad version. Does anyone know how I achieve this format?
Solved! Go to Solution.
2022-09-10 04:41 AM
You could set the Property ID of the Door to 2668 and use the Property Label. It is quite versatile. You can use a frame if you want and have it opaque.
2022-09-08 12:30 AM
you could use an associative label tool that calls up whatever parameter it is you're grabbing from the door.
above is an example calling up the panel height.
2022-09-10 01:16 AM - edited 2022-09-10 01:22 AM
It's not displaying the format that I am after.
2022-09-10 04:41 AM
