How do I do this Dimensions Marker format?
INTEXHOMES
Dimension marker 22 was a great marker. Unfortunately removed from the current Archicad version. Does anyone know how I achieve this format?
Gerald Hoffman
You could set the Property ID of the Door to 2668 and use the Property Label. It is quite versatile. You can use a frame if you want and have it opaque.
Screen Shot 2022-09-09 at 7.36.39 PM.pngScreen Shot 2022-09-09 at 7.38.16 PM.png
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 27-6000 USA
2019 MacBook Pro-macOS 15.0 (64GB w/ AMD Radeon Pro 5600M GPU)
Gerry Leonor
you could use an associative label tool that calls up whatever parameter it is you're grabbing from the door.
above is an example calling up the panel height.
AC25 | Win10 | 64Gb RAM | Intel i7 13700F | RTX 4070 Ti
https://discord.gg/XGHjyvutt8
It's not displaying the format that I am after.
Gerald Hoffman
Gerald Hoffman
