PYA
Can't place any object even Archicad object.
Out of sudden from nowhere.  I can't place object any more for this specific file.  If I open other file or new one, I am able to do so. I thought it must be corrupted file and need repair. After doing repair, nothing change.
When I click on the screen, nothing happen, besides a message appeared in the right side of bottom and disappeared very quick, I was able to use video to captured: the message saying: Saint to Recovery File...
I have check all setting. I even turn on all layers. turn off graphics override.
I can see my previous placed object in the screen, but I just can't place another one.
Anything else I missing?
Archicad 25-27
MacBook Pro M1 Max 64GB Sonoma 14
1 Solution
Lingwisyer
Guru
Check your layers, it might have been placing on a hidden layer? Not sure if it actually allows you to do this.
Check your 3D, might it be placing outside of your floor plan display range?
Go to post
3 Replies 3
Lingwisyer
Guru
Even if you eye dropper an existing object?
AC version? Windows?
Please do not just add random tags...
PYA
Thanks, Lingwisyer,  I used eyedropper, and fixed the issue. I don't know why, but I will remember this trick.
I used Mac. AC25
Archicad 25-27
Lingwisyer
Guru
