INTEXHOMES
How do I do this Dimensions Marker format?
Dimension marker 22 was a great marker. Unfortunately removed from the current Archicad version. Does anyone know how I achieve this format?
1 Solution
You could set the Property ID of the Door to 2668 and use the Property Label. It is quite versatile. You can use a frame if you want and have it opaque.
Screen Shot 2022-09-09 at 7.36.39 PM.pngScreen Shot 2022-09-09 at 7.38.16 PM.png
Gerald Hoffman
Archicad 4.55 - 29-Latest USA
Go to post
3 Replies 3
Gerry Leonor
you could use an associative label tool that calls up whatever parameter it is you're grabbing from the door.
above is an example calling up the panel height.
https://discord.gg/XGHjyvutt8
INTEXHOMES
It's not displaying the format that I am after.
Gerald Hoffman
