Can't place any object even Archicad object.
PYA
Out of sudden from nowhere.  I can't place object any more for this specific file.  If I open other file or new one, I am able to do so. I thought it must be corrupted file and need repair. After doing repair, nothing change.
When I click on the screen, nothing happen, besides a message appeared in the right side of bottom and disappeared very quick, I was able to use video to captured: the message saying: Saint to Recovery File...
I have check all setting. I even turn on all layers. turn off graphics override.
I can see my previous placed object in the screen, but I just can't place another one.
Anything else I missing?
Archicad 25-27
MacBook Pro M1 Max 64GB Sonoma 14
Guru
Check your layers, it might have been placing on a hidden layer? Not sure if it actually allows you to do this.
Check your 3D, might it be placing outside of your floor plan display range?
Guru
Even if you eye dropper an existing object?
AC version? Windows?
Please do not just add random tags...
PYA
Thanks, Lingwisyer,  I used eyedropper, and fixed the issue. I don't know why, but I will remember this trick.
I used Mac. AC25
Archicad 25-27
Guru
