Document & Visualize forum
How do I remove these from my elevations
Cant figure out how i did this ! but i want to remove the end points from my drawings ! turn off... I dont know what there called .
Just learning cheers
David Maudlin
tiemi:
Those are probably Hotspots. You can select the Hotspot tool, Select All command (which will select all the Hotspots) than Delete.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC26 USA • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX10.15.7
Lingwisyer
Legend
Note: Hotspots do not publish.
Win10 | R5 2600 | 16GB | GTX1660
