Import Publishing set to a new project...
Llian
How do I import publishing set from existing to the new project?
The new project doesn't have the set…
Thanks
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
4 REPLIES 4
Eduardo Rolon
Try the following:
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Llian
thanks Eduardo….it doesn't work.
looking through past posts, look like there is no way to import publishing sets from an existing to the new project…I forgot to use the template I have set up and have already done so much work on it. I think I will open a template an copy and paste. thanks anyways!
Publisher Set items are based either on Views, or Layouts (which have Drawings based on Views). Views can not be exported-imported between Projects, I suppose because of the complexity associated with the process (you would have to export-import all settings that Views reference). I think this is the reason why Publisher Sets can not be exported-imported between Projects either.
Eduardo Rolon
Uff, misread the question to mean Layouts, sorry.
AC29 US/INT -> AC08
another Moderator
