Document & Visualize forum
Section Text Overrides size
Eduardo Rolon
Using Built In Section Marker cannot edit Text Overrides font size and it is in MM instead of points.
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro 2.4 i9 32GB ram
OS X 10.XX latest
AC25 US/INT -> AC08
It looks like a bug. The font size becomes active when the Working Units are set to to some form of Metric, but is inactive when using Imperial Units.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC24 USA • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX10.14.6
Odd it is working for me (version 22).
Yes it is in mm but I don't use points anyway.
If you don't override any of the lines, can you edit in the main 'Marker Text Style' section - this all becomes un-editable when a line override is chosen
Versions 6.5 to 25
Daniel Kovacs
David is right, this is a bug (fix #254885). I let the developers know, and they will fix it as soon as possible.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
