Two-piece Flooring
Hi, I've divided the flooring floor into two parts. How do I combine these two pieces?
If they are slabs, then select one and using the pet palette options you can add an area to that slab .
Add the area described by the second slab - either by manually picking its nodes or by magic wanding on it.
Then you have to delete the second slab - it does not merge them.
Or just manually adjust the edges and nodes of one of the slabs and delete the other.
Unfortunately there is no way to merge two slabs.
Thanks a lot. I did the first thing you said, but I felt like I was doing something wrong. I just wanted to ask you to be sure.
