graphics override
Claudio Lima
hi all !
any one have a solution for this modeling process ?
one wall and another wall as finishing .
then, I wanna GO so all the walls will be with the same fill, but, no line between them.
tnks
best
claudio
since ARCHICAD 3.42 to ARCHICAD 26
13 REPLIES 13
A complex profile can have as many finishes vertically as you want.
With modifiers you can adjusts the heights of these surfaces without having to create new walls.
You can even turn them off by stretching the height to zero.
Horizontally is another matter.
You have to split the wall.
But you can use the same wall composite with modifiers and adjust the height of the bottom material to zero.
hi barry !
I used to use complex profiles, but then, I started to have quantifications problems
It was in Archicad previous versions..., I will teste it...
tnks
c
nop, doesn't work...
For those schematic plans I just go for a graphic override turning cut fills into a Solid Fill, same pen color as wall outline fill.
