Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
2D Floor Symbol Visibility of the Base Fixing of the Railing Post-type Components (Post, Inner Post)
Reysol
Guys,
Is there a way to make the railing base fixing symbol visible on floor plan?
I am specifically talking about the base fixing of the post-type components of the railing. See 'Base Fixing' in the red circle in the attached photo.
Thanks a lot, guys.
@Ricardo Lopez wrote:
There is an option available for Fixing Floor Plan Symbol with a couple of options. May be this could help...
Thanks @Ricardo Lopez
I totally missed that, but that is because it is available only when you are using the side fixing method.
6 REPLIES 6
No.
There is only a symbolic representation of the post.
Reysol
Barry,
Thank you very much for the reply. Appreciate it.
Reysol.
Ricardo Lopez
Hi @Reysol
Regards
M. Arch. Ricardo López
AC17-27 SPA+INT | Windows 11 | MSI WE75 9TK, 32GB, Nvidia Quadro RTX 3000
Hi Ricardo,
Thanks a lot for looking into this.
Barry,
Thanks again for the comments.
Yes, the Side Fixing has the 2D symbol visible on floor plans. But, the Base Fixing does not get the same privilege.
Setup info provided by author
