DGSketcher
Legend
3D Document dimensions
I have an Axonometric view of a component isolated in a 3D document. I can't dimension the length of an inclined edge. Is this a known limitation of 3D documents or am I missing a trick?
1 Solution
It can be done.
Place a horizontal dimension and then re-align it.
Go to post
3 Replies 3
daviiiiidave
i played some time with the dimension tool but i couldnt make it happen either. i think it is a limitation. cause if you make an 3Ddoc which is not an "elevation" you can grab the dimension. it seems the dimension tool needs to be referenced to the face of the inclined element.
in the "elevation" it seem the dimension is only working in x or y direction.
Both screenshots are from an axonometric 3Ddocs.
ARCHICAD 19-25, Student & Full Archicard, CI Tools, Germany
Mifcom Renderbox AMD Ryzen 9 5900X GeForce RTX 3070 TI 32GB RAM 980 PRO SSD Win10
Thinkpad P52 4K i7 8850H NVIDIA Quadro P3200 (6 GB) 32 GB RAM SSD Win10 Pro
It can be done.
DGSketcher
Legend
Thanks for the replies.
Barry - In relation to all the other dimensioning options, the pet pallet was the last place I was looking for a solution. Not the most user friendly method of dimensioning, but now I know there is a way. Thank you.
