2020-08-03
05:11 PM
- last edited on
2023-05-26
12:01 AM
by
Gordana Radonic
2020-08-10 09:38 AM
2020-08-10 12:31 PM
LaszloNagy wrote:I know its not the solution for the issue. But I would just add in 2 to make sure your groups are On. In case you have any modules on your project. (Just for the record)
1. With your Project open, use the File > New > New command, and use the "Latest Project Settings" option, plus check the "Launch a new instance of Archicad" checkbox.
2. Now that you have both instance of Archicad and both are using the same project settings such as attributes, etc., you can go to your project, make all Layers visible, unlock all Layers and all elements, then select all elements and press CTRL+C.
3. Go to your new, empty project, and press CTL+V to paste all elements into it. It will also paste Sections, Elevations, etc.
2020-08-10 03:07 PM
2020-08-10 05:19 PM
2020-08-10 09:22 PM
